    1310 Benutzer registriert, davon online: 292 Gäste
Keine neuen Beiträge, seit Ihrem letzten Besuch am 30.11.2026 - 19:29.
Forenübersicht » Talk » Installation Guide: TwinZ Design Bolt-on Diffuser
21 Beiträge in diesem Thema (offen)
Themenicon    Installation Guide: TwinZ Design Bolt-on Diffuser
26 Beiträge - Member
dB Warrior`s alternatives Ego
Hey zusammen....
Habe hier noch eine "funktionierende" Anleitung für den Anbau des TwinZ Design Bolt On Diffuser gefunden. cool
Viel Spass beim Zusammenbau...
EDIT:
Achtung....
Dies ist ist für die US Version (2 Plätzer)
Die EU Version hat anderes Montagezubehör und wird in gewissen Punkten auch auf eine andere Weise montiert.
Zitat: Australian ZX Forum
For the right installation of your TwinZ Design bolt-on diffuser we recommend following these steps to get the best attachment and fitment to your OEM rear bumper and chassis.
The diffuser comes with:
- 2 metal brackets
- 8 bolts (10mm)
- 8 nuts (10mm)
- 16 big washers
- 4 stobols
- 4 nuts (8mm)
- 8 small washers
5_TwinZDesignDiffuser20attachmentpoints
INSTALL PROCESS:
1. Remove the OEM rear bumper out of the car.
2. Unbolt the catback section of the exhaust system to make the installation easier.
3. Once you have the OEM rear bumper out, place the bolt-on diffuser under the OEM rear bumper until to get the mounting points as pictured.
65_TwinZDesignDiffuserinstall1.1
4. Use 2 stobols to attach the middle section of the bumper with the diffuser.
36_TwinZDesignDiffuserinstall3
5. Proceed to install the OEM rear bumper with the diffuser partially attached to it.
6. While installing the bumper, be VERY CAREFULL with the attaching points above the exhaust opennings. You will have to press down this part of the bumper and diffuser together with both of your hands and place them in front of the aluminium bumper bar as pictured bellow. If you don't do it this way, you could damage this attaching point.
47_TwinZDesignDiffuserinstall4
7. Bolt the attaching points over the exhaust opennings and the ones near the bumper wheel arch as pictured.
25_TwinZDesignDiffuserinstall5.1
8. Use the attachment brackets to attach the lower section of the diffuser with the chassis.
95_TwinZDesignDiffuserinstall7.1
9. Press the diffuser against the bumper and bolt the license plate section of the diffuser to the bumper using 2 stobols to get the best fitment.
34_TwinZDesignDiffuserinstall9
10. Some OEM bumpers get wavy with time, so we recommend using Sikaflex silicon on the rear section of the diffuser to ensure the best seal and fitment between the diffuser and bumper.
63_TwinZDesignDiffuserinstall10,1
Greetz Marco
Dieser Beitrag wurde 3 mal editiert, zuletzt von dB Warrior am 11.08.2012 - 14:51.
Beitrag vom 10.08.2012 - 21:49
Marktplatz Marktplatz TwinZ Design - Letzte Antwort von steve am 25.04.15 - 11:36 TwinZ Design - steve - 25.04.15 - 11:36
Technik Technik Gutachten für TwinZ Design - Letzte Antwort von para-dox am 29.08.13 - 06:55 Gutachten für TwinZ Design - para-dox - 29.08.13 - 06:55
Marktplatz Marktplatz TwinZ Design Lippen+Diffusor - Letzte Antwort von ste_kop am 02.06.20 - 09:52 TwinZ Design Lippen+Diffusor - ste_kop - 02.06.20 - 09:52
Marktplatz Marktplatz TwinZ Design Products now available for Pre-Order! - Letzte Antwort von Sabrizuta am 10.02.13 - 10:59 TwinZ Design Products now available for Pre-Order! - Sabrizuta - 10.02.13 - 10:59
Marktplatz Marktplatz Neue Preorder für TwinZ Design Teile - Letzte Antwort von Sabrizuta am 03.08.13 - 13:59 Neue Preorder für TwinZ Design Teile - Sabrizuta - 03.08.13 - 13:59
Beiträge Autor Datum
dB Warrior 10.08.2012 - 21:49
Pladinmadin 22.08.2013 - 09:58
KingOlli 22.08.2013 - 10:21
Sabrizuta 22.08.2013 - 10:24
Gerd 22.08.2013 - 10:29
Pladinmadin 22.08.2013 - 10:59
Gerd 22.08.2013 - 11:07
Sabrizuta 22.08.2013 - 14:37
KingOlli 22.08.2013 - 21:43
Pladinmadin 22.08.2013 - 22:02
Gerd 24.08.2013 - 12:26
KingOlli 24.08.2013 - 16:25
yellowzx 24.08.2013 - 17:26
Pladinmadin 24.08.2013 - 20:17
Gerd 25.08.2013 - 13:01
yellowzx 25.08.2013 - 18:16
Pladinmadin 19.09.2013 - 21:21
KingOlli 19.09.2013 - 21:31
Pladinmadin 19.09.2013 - 22:18
yellowzx 20.09.2013 - 11:16
adolf300zx 20.09.2013 - 18:51
Es ist / sind gerade 0 registrierte(r) Benutzer und 292 Gäste online. Neuester Benutzer: Libanon Z32
Seite in 0.02178 Sekunden generiert
